跳转到主内容
iRobot Looj 120 Controller Buttons Replacement
你所需要的
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: 步骤 1 中的图像 1,1
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: 步骤 2 中的图像 1,1
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: 步骤 3 中的图像 1,1
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: 步骤 4 中的图像 1,1
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
结论
另外一个人完成了本指南。
Lucas Otto
于11/12/14注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 227
