简介
The following guide will show you how to remove and replace your cleaning head module on the Roomba i6 model. For this task you will need a long PH1 size screwdriver and a PH 2 screwdriver. You will not need to keep track of any screws.
你所需要的
Using your PH2 size screwdriver, remove the edge sweeping brush by unscrewing the single screw
Using your PH2 screwdriver, remove all 5 of the screws.
The two screws up top will keep unscrewing all the way if you don't stop. Stop unscrewing as soon as you feel a noticeable change in resistance.
After all screws are unscrewed, gently lift the bottom cover straight up from the two points the arrows are pointing to.
Remove the battery by pushing the plastic clip up and lifting the battery out of the Roomba.
Unscrew all 4 screws highlighted in red using your PH1 size screwdriver.
After all screws are removed, gently lift the cleaning module by inserting your fingers into the slit highlighted in blue and lifting straight up.
To install the replacement module, follow these instructions in reverse order.
