跳转到主内容
iRobot Roomba 980 Rear Wheels
你所需要的
  1. iRobot Roomba 980 Rear Wheels, Battery: 步骤 1 中的图像 1,1
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Rear Wheels: 步骤 2 中的图像 1,2 iRobot Roomba 980 Rear Wheels: 步骤 2 中的图像 2,2
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Rear Wheels: 步骤 3 中的图像 1,2 iRobot Roomba 980 Rear Wheels: 步骤 3 中的图像 2,2
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Rear Wheels, Rear Wheels: 步骤 4 中的图像 1,2 iRobot Roomba 980 Rear Wheels, Rear Wheels: 步骤 4 中的图像 2,2
    • Loosen the screw on the side brush.
    • Lift the side brush from the device.
  5. iRobot Roomba 980 Rear Wheels: 步骤 5 中的图像 1,2 iRobot Roomba 980 Rear Wheels: 步骤 5 中的图像 2,2
    • Unscrew the (2) 11.5mm screws using the Phillips #1 screwdriver.
    • Carefully remove the plate by lifting it off of the device.
  6. iRobot Roomba 980 Rear Wheels: 步骤 6 中的图像 1,2 iRobot Roomba 980 Rear Wheels: 步骤 6 中的图像 2,2
    • Removing the brush module may ease the removal of the wheel module
    • Locate the (3) 15.8mm gold Phillips #1 screws and unscrew them.
    • Lift the wheel module removing it from the vacuum.
    • Remove the other wheel by repeating these steps.
结论
4等其他人完成本指南。
团队
USF Tampa, Team S14-G2, Boczar Fall 2017 USF Tampa, Team S14-G2, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S14G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 3,195
