跳转到主内容
iRobot Roomba 960 Filter Replacement
你所需要的
  1. iRobot Roomba 960 Filter Replacement, Filter: 步骤 1 中的图像 1,1
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
  2. iRobot Roomba 960 Filter Replacement: 步骤 2 中的图像 1,3 iRobot Roomba 960 Filter Replacement: 步骤 2 中的图像 2,3 iRobot Roomba 960 Filter Replacement: 步骤 2 中的图像 3,3
    • Press the large button on the Roomba that is located closest to you.
    • Pull to remove the dust bin.
  3. iRobot Roomba 960 Filter Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 960 Filter Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 960 Filter Replacement: 步骤 3 中的图像 3,3
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right (there is a yellow arrow pointing to it).
    • Lift the red plastic cover to access the filter.
  4. iRobot Roomba 960 Filter Replacement: 步骤 4 中的图像 1,3 iRobot Roomba 960 Filter Replacement: 步骤 4 中的图像 2,3 iRobot Roomba 960 Filter Replacement: 步骤 4 中的图像 3,3
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
结论
另外一个人完成了本指南。
Vanessa Greyson
于02/02/17注册
471 声望
创作了3篇指南
团队
USF Tampa, Team 16-3, Blackwell Spring 2017 USF Tampa, Team 16-3, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G3
4 名成员
创作了6篇指南
一条评论
I need to replace the red bin cover over the filter, do I need to unscrew the black piece or something or just try to pry it out. I don’t want to break it.
Sandra Freed - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 26
总计 2,159
