跳转到主内容
iRobot Roomba 891 Battery Replacement
你所需要的
  1. iRobot Roomba 891 Battery Replacement, Battery: 步骤 1 中的图像 1,2 iRobot Roomba 891 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: 步骤 2 中的图像 1,1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 891 Battery Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 891 Battery Replacement: 步骤 3 中的图像 3,3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
结论
3等其他人完成本指南。
1指南评论
justin i added a push pin to step 1
thomas Wilson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 1,024
