跳转到主内容
iRobot Roomba 890 Charging Contacts Replacement
你所需要的
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: 步骤 1 中的图像 1,2 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: 步骤 1 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: 步骤 2 中的图像 1,1
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: 步骤 3 中的图像 1,1
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: 步骤 4 中的图像 1,2 iRobot Roomba 890 Charging Contacts Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 890 Charging Contacts Replacement: 步骤 5 中的图像 2,2
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: 步骤 6 中的图像 1,2 iRobot Roomba 890 Charging Contacts Replacement: 步骤 6 中的图像 2,2
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: 步骤 7 中的图像 1,3 iRobot Roomba 890 Charging Contacts Replacement: 步骤 7 中的图像 2,3 iRobot Roomba 890 Charging Contacts Replacement: 步骤 7 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: 步骤 8 中的图像 1,2 iRobot Roomba 890 Charging Contacts Replacement: 步骤 8 中的图像 2,2
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: 步骤 11 中的图像 1,1
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
结论
2等其他人完成本指南。
Devin Steiblin
于03/28/22注册
442 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G3
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 20
过去 30 天: 145
总计 4,048
