跳转到主内容
iRobot Roomba 880 Cleaning Head Replacement
你所需要的
  1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: 步骤 1 中的图像 1,3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: 步骤 1 中的图像 2,3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: 步骤 1 中的图像 3,3
    • Flip the Roomba over, wheel-side up.
    • Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
    • Remove the battery door, pulling straight up from the two indents above the screws.
  2. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: 步骤 2 中的图像 1,2 iRobot Roomba 880 Cleaning Head Replacement, Side Brush: 步骤 2 中的图像 2,2
    • Using a flat head screwdriver, loosen the screw on the top of the side brush.
    • Remove side brush.
    • The bottom panel cannot be removed without first removing the side brush, so make sure to do this first.
  3. iRobot Roomba 880 Cleaning Head Replacement, Bottom Panel: 步骤 3 中的图像 1,1
    • Pull up on the bottom panel to remove.
  4. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: 步骤 4 中的图像 1,2 iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: 步骤 4 中的图像 2,2
    • Reach underneath the dust bin, press the bin removal button, and pull out.
    • The bin removal button is located on the top edge of the bin.
  5. iRobot Roomba 880 Cleaning Head Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 880 Cleaning Head Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
  6. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: 步骤 6 中的图像 1,3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: 步骤 6 中的图像 2,3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: 步骤 6 中的图像 3,3
    • Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
结论
另外一个人完成了本指南。
Allie Ahern
于04/27/17注册
130 声望
撰写一个指南
团队
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G4
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 2,156
