简介
This guide will show you how to replace the whole Cleaning Head in the Roomba 880, which houses the Debris Extractors. Let's do it!
你所需要的
Flip the Roomba over, wheel-side up.
Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
Remove the battery door, pulling straight up from the two indents above the screws.
Using a flat head screwdriver, loosen the screw on the top of the side brush.
Remove side brush.
Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
另外一个人完成了本指南。
