跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
iRobot Roomba 880 Battery Replacement
你所需要的
  1. iRobot Roomba 880 Battery Replacement, Battery: 步骤 1 中的图像 1,2 iRobot Roomba 880 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 880 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the battery using the green tabs on either side of the battery.
结论
另外一个人完成了本指南。
Frances Belcher
于04/18/17注册
420 声望
创作了2篇指南
团队
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G4
5 名成员
创作了5篇指南
一条评论
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 30
总计 4,598
