跳转到主内容
iRobot Roomba 870 Side Brush Motor Replacement
你所需要的
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 步骤 1 中的图像 1,3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 步骤 1 中的图像 2,3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 步骤 1 中的图像 3,3
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 3 中的图像 2,2
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: 步骤 4 中的图像 1,3 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 4 中的图像 2,3 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 4 中的图像 3,3
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: 步骤 5 中的图像 1,3 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 5 中的图像 2,3 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 5 中的图像 3,3
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: 步骤 6 中的图像 1,3 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 6 中的图像 2,3 iRobot Roomba 870 Side Brush Motor Replacement: 步骤 6 中的图像 3,3
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 3,595
