跳转到主内容
iRobot Roomba 870 Main Wheel Replacement
你所需要的
  1. iRobot Roomba 870 Main Wheel Replacement, Main Wheel: 步骤 1 中的图像 1,2 iRobot Roomba 870 Main Wheel Replacement, Main Wheel: 步骤 1 中的图像 2,2
    • While the Roomba is upside down, remove the 4.0mm screw surrounding the side brush using a Phillips #2 screwdriver.
    • Remove the brush.
  2. iRobot Roomba 870 Main Wheel Replacement: 步骤 2 中的图像 1,3 iRobot Roomba 870 Main Wheel Replacement: 步骤 2 中的图像 2,3 iRobot Roomba 870 Main Wheel Replacement: 步骤 2 中的图像 3,3
    • Unscrew the four 3.5mm screws on the back cover using a Phillips #2 screwdriver.
    • Remove the back cover.
  3. iRobot Roomba 870 Main Wheel Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 870 Main Wheel Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 870 Main Wheel Replacement: 步骤 3 中的图像 3,3
    • Unscrew the six 3.5mm screws using a Phillips #00 screwdriver. Each wheel has three screws.
    • Once all the screws are out, take out the wheels.
结论
6等其他人完成本指南。
Andrew Cabri
于04/24/17注册
330 声望
创作了2篇指南
团队
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G3
4 名成员
创作了10篇指南
一条评论
In step 3, the screw positions are just a bit off. They are not under the corners of the battery but under into the wheel housing.
aarond12 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 4,651
