跳转到主内容
iRobot Roomba 870 Battery Replacement
你所需要的
  1. iRobot Roomba 870 Battery Replacement, Battery: 步骤 1 中的图像 1,2 iRobot Roomba 870 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: 步骤 2 中的图像 1,3 iRobot Roomba 870 Battery Replacement: 步骤 2 中的图像 2,3 iRobot Roomba 870 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
结论
Follow the steps in reverse order for reassembly.
2等其他人完成本指南。
Vitek Harvey
于04/26/17注册
149 声望
撰写一个指南
团队
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 3,348
