跳转到主内容
iRobot Roomba 870 Bumper Sensor Replacement
你所需要的
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: 步骤 1 中的图像 1,2 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: 步骤 1 中的图像 2,2
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: 步骤 2 中的图像 1,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 2 中的图像 2,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 2 中的图像 3,3
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 3 中的图像 3,3
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: 步骤 4 中的图像 1,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 4 中的图像 2,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 4 中的图像 3,3
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 5 中的图像 2,2
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: 步骤 6 中的图像 1,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 6 中的图像 2,3 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 6 中的图像 3,3
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: 步骤 7 中的图像 1,2 iRobot Roomba 870  Bumper Sensor Replacement: 步骤 7 中的图像 2,2
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
结论
13等其他人完成本指南。
Jacob Lindberg
于04/19/17注册
449 声望
撰写一个指南
团队
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G3
4 名成员
创作了10篇指南
3指南评论
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - 回复
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - 回复
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 63
总计 8,448
