跳转到主内容
加入维修社区 - 创建账户
iRobot Roomba 860 Side Wheel Assembly Replacement
你所需要的
    1. iRobot Roomba 860 Side Wheel Assembly Replacement, Debris Extractors: 步骤 1 中的图像 1,2 iRobot Roomba 860 Side Wheel Assembly Replacement, Debris Extractors: 步骤 1 中的图像 2,2
      • To remove the debris extractor, first begin by removing and emptying the trash bin.
      • Push down and pull out on the silver button located on the top of the Roomba in the back.
      • The trash bin should then slide out.
      询问修复机器人
      添加评论
    2. iRobot Roomba 860 Side Wheel Assembly Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 860 Side Wheel Assembly Replacement: 步骤 2 中的图像 2,2
      • With the Roomba upside down, locate the two yellow buttons by the extractor.
      • To open the flap holding the extractos in place, pinch the two yellow buttons together towards the center and pull up on the flap at the same time
      询问修复机器人
      添加评论
    3. iRobot Roomba 860 Side Wheel Assembly Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 860 Side Wheel Assembly Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 860 Side Wheel Assembly Replacement: 步骤 3 中的图像 3,3
      • Once the flap is open, grab the yellow end of the dark gray extractor and pull up slightly.
      • After lifting it up about an inch, pull it out towards one of the side wheels.
      • The extractor should slide out with ease. Repeat the same procedure for the light gray debris extractor.
      询问修复机器人
      添加评论
    1. iRobot Roomba 860 Side Wheel Assembly Replacement, Side Wheel Assembly: 步骤 4 中的图像 1,2 iRobot Roomba 860 Side Wheel Assembly Replacement, Side Wheel Assembly: 步骤 4 中的图像 2,2
      • To remove the Side Wheel Assembly, start by locating 2 15mm Phillips #2 Point screws above the wheels.
      • Remove the screws and pull up on the plate surrounding the side wheels.
      询问修复机器人
      添加评论
      • Locate and remove 3x Phillips #0 Point Screws located behind the yellow side brush, bottom let corner of heel assembly, and on the outside of the wheel assembly.
      询问修复机器人
      添加评论
      • With all the screws removed, lift up on the side wheel assembly to remove it from the Roomba housing.
      • The other wheel can be removed and replaced the same way
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Ryan Murphy
于03/02/17注册
461 声望
创作了4篇指南
团队
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G5
4 名成员
创作了48篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 106
总计 1,930
