跳转到主内容
iRobot Roomba 860 Side Brush Replacement
你所需要的
  1. iRobot Roomba 860 Side Brush Replacement, Side Brush: 步骤 1 中的图像 1,1
    • Start by locating the yellow side brush on the underside of the iRobot Roomba 860 near the front of the device.
  2. iRobot Roomba 860 Side Brush Replacement: 步骤 2 中的图像 1,1
    • Using a Philips #2 Point Screwdriver, remove the screw located in the center of the brush.
  3. iRobot Roomba 860 Side Brush Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 860 Side Brush Replacement: 步骤 3 中的图像 2,2
    • Pull up on the side brush and it should slide off, free of the motor shaft.
    • Remove any debris that could be preventing the side brush from spinning and/or replace the side brush.
结论
Ryan Murphy
于03/02/17注册
446 声望
创作了4篇指南
团队
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G5
4 名成员
创作了4篇指南
一条评论
What to do if the screw head is broken off? Thanks
Linda - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 927
