跳转到主内容
iRobot Roomba 860 Filter Replacement
  1. iRobot Roomba 860 Filter Replacement, Filter: 步骤 1 中的图像 1,3 iRobot Roomba 860 Filter Replacement, Filter: 步骤 1 中的图像 2,3 iRobot Roomba 860 Filter Replacement, Filter: 步骤 1 中的图像 3,3
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
    • Press the large button on the Roomba that is located closest to you.
    • Pull towards you to remove dust bin.
    • Now place dust bin flat with the large button towards you.
  2. iRobot Roomba 860 Filter Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 860 Filter Replacement: 步骤 2 中的图像 2,2
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right.
    • Now lift red plastic cover to begin removing the filter.
  3. iRobot Roomba 860 Filter Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 860 Filter Replacement: 步骤 3 中的图像 2,2
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
结论
Stephen Yezukevicz
于11/06/18注册
193 声望
创作了2篇指南
团队
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 308
