跳转到主内容
iRobot Roomba 860 Debris Extractor Cleaning / Replacement
你所需要的
  1. iRobot Roomba 860 Debris Extractor Cleaning / Replacement, Debris Extractors: 步骤 1 中的图像 1,2 iRobot Roomba 860 Debris Extractor Cleaning / Replacement, Debris Extractors: 步骤 1 中的图像 2,2
    • To remove the debris extractor, first begin by removing and emptying the trash bin.
    • Push down and pull out on the silver button located on the top of the Roomba in the back.
    • The trash bin should then slide out.
  2. iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 步骤 2 中的图像 2,2
    • With the Roomba upside down, locate the two yellow buttons by the extractor.
    • To open the flap holding the extractos in place, pinch the two yellow buttons together towards the center and pull up on the flap at the same time
  3. iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 步骤 3 中的图像 3,3
    • Once the flap is open, grab the yellow end of the dark gray extractor and pull up slightly.
    • After lifting it up about an inch, pull it out towards one of the side wheels.
    • The extractor should slide out with ease. Repeat the same procedure for the light gray debris extractor.
结论
2等其他人完成本指南。
Ryan Murphy
于03/02/17注册
446 声望
创作了4篇指南
团队
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G5
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 23
总计 1,515
