跳转到主内容
iRobot Roomba 860 Bumper & Bumper Sensor Replacement
你所需要的
  1. iRobot Roomba 860 Bumper & Bumper Sensor Replacement, Bumper & Bumper Sensor: 步骤 1 中的图像 1,2 iRobot Roomba 860 Bumper & Bumper Sensor Replacement, Bumper & Bumper Sensor: 步骤 1 中的图像 2,2
    • Place Roomba flat on table with iRobot text upside down and closest to you.
    • Detach the clips on the bumper.
    • Flip Roomba so that the bottom side is facing up and you can access bottom screws on bumper.
  2. iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the two screws.
  3. iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 步骤 3 中的图像 2,2
    • Once the screws are removed, the wire will detach from the bumper and sensor with very light force.
结论
另外一个人完成了本指南。
Danny Andrade
于11/01/18注册
121 声望
撰写一个指南
团队
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G5
3 名成员
创作了3篇指南
一条评论
Very good directions for disassembly. Can you add specific instructions for re-assembly?
If you have any suggestions for getting the main part of the bumper back on, that would be helpful. It was very challenging to get that part reattached to the chassis. There is a tab at each end of the main part of the bumper, and it was challenging to get them into their respective slots. It required a lot of pushing and pulling and compressing of the main bumper part, and although the tabs finally went where they were supposed to go, I’m not sure what I did to get them there.
S Butler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 1,645
