跳转到主内容
iRobot Roomba 860 Battery Replacement
你所需要的
  1. iRobot Roomba 860 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Start by powering down the device to remove the battery from the iRobot Roomba 860.
  2. iRobot Roomba 860 Battery Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 860 Battery Replacement: 步骤 2 中的图像 2,2
    • Flip the Roomba over so that the underside is facing up.
    • Locate the battery panel and the 2 - 7 mm Phillips #2 Point Screws.
    • Using a Phillips #2 Point Screwdriver, remove the screws and use your fingers to pull the cover away from the device.
  3. iRobot Roomba 860 Battery Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 860 Battery Replacement: 步骤 3 中的图像 2,2
    • Locate the two fabric tabs on the side of the battery.
    • Pull up on the tabs to easily remove the battery.
结论
Ryan Murphy
于03/02/17注册
446 声望
创作了4篇指南
团队
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 1,059
