跳转到主内容
iRobot Roomba 770 Brush Replacement
  1. iRobot Roomba 770 Brush Replacement, Brush: 步骤 1 中的图像 1,1
    • Orient the roomba so it is upside down and the dust tray is closest to you.
  2. iRobot Roomba 770 Brush Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 770 Brush Replacement: 步骤 2 中的图像 2,2
    • Locate the two yellow tabs on the screen that covers the brushes.
    • Push inwards on the yellow tabs while simultaneously pulling upwards on the attached grey cage.
  3. iRobot Roomba 770 Brush Replacement: 步骤 3 中的图像 1,3 iRobot Roomba 770 Brush Replacement: 步骤 3 中的图像 2,3 iRobot Roomba 770 Brush Replacement: 步骤 3 中的图像 3,3
    • Grab the right side of the larger brush that is located near the yellow cap. Pull upwards and to the right to remove the brush.
    • Repeat the same steps with the smaller brush.
  4. iRobot Roomba 770 Brush Replacement: 步骤 4 中的图像 1,2 iRobot Roomba 770 Brush Replacement: 步骤 4 中的图像 2,2
    • Orient the brush so the yellow tab is on the right hand side.
    • Pull the yellow tab to the right to remove.
    • Remove any debris, paying attention to the ends as well as the brush itself.
    • Replace any damaged brushes.
结论
Andrew Horvath
于10/05/16注册
444 声望
创作了3篇指南
团队
Cal Poly, Team 15-3, Livingston Fall 2016 Cal Poly, Team 15-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G3
3 名成员
创作了5篇指南
一条评论
My roomba starts and moves a foot or so and then stops. I have cleaned it entirely, the battery is fine and the wheels are clean. Anyone have a suggestion
Mary Ann Dyer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,274
