跳转到主内容
iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal
你所需要的
  1. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: 步骤 1 中的图像 2,2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: 步骤 2 中的图像 1,2 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
结论
Matt Davis
于01/22/15注册
1,642 声望
创作了7篇指南
团队
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G20
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 1,588
