跳转到主内容
iRobot Roomba 655 Pet Series Side Brush Motor Replacement
你所需要的
  1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: 步骤 1 中的图像 1,3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: 步骤 1 中的图像 2,3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: 步骤 1 中的图像 3,3
    • First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
    • Pull the brush motor out
  2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: 步骤 2 中的图像 1,3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: 步骤 2 中的图像 2,3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: 步骤 2 中的图像 3,3
    • Next, with the same head remove the screw holding the plastic housing together
    • Carefully pry the gear box open by placing a flat head screwdriver in the slot
    • This might be difficult and require some shifting of the screwdriver
  3. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: 步骤 3 中的图像 1,3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: 步骤 3 中的图像 2,3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: 步骤 3 中的图像 3,3
    • Removing these two screws will allow you to access the motor (use the same head as before)
结论
2等其他人完成本指南。
Matt Davis
于01/22/15注册
1,642 声望
创作了7篇指南
团队
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G20
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 1,664
