跳转到主内容
iRobot Roomba 655 Pet Series Internal Faceplate Removal
你所需要的
  1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: 步骤 1 中的图像 1,2 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: 步骤 1 中的图像 2,2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: 步骤 2 中的图像 1,2 iRobot Roomba 655 Pet Series Internal Faceplate Removal: 步骤 2 中的图像 2,2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: 步骤 3 中的图像 1,2 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: 步骤 3 中的图像 2,2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Internal Faceplate Removal: 步骤 4 中的图像 1,3 iRobot Roomba 655 Pet Series Internal Faceplate Removal: 步骤 4 中的图像 2,3 iRobot Roomba 655 Pet Series Internal Faceplate Removal: 步骤 4 中的图像 3,3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: 步骤 5 中的图像 1,3 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: 步骤 5 中的图像 2,3 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: 步骤 5 中的图像 3,3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
结论
Rhett
于01/22/15注册
1,329 声望
创作了7篇指南
团队
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G20
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 763
