跳转到主内容
iRobot Roomba 655 Pet Series Drive Wheels Replacement
你所需要的
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: 步骤 1 中的图像 2,2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: 步骤 2 中的图像 1,2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: 步骤 3 中的图像 1,3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: 步骤 3 中的图像 2,3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: 步骤 3 中的图像 3,3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: 步骤 4 中的图像 1,2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: 步骤 4 中的图像 2,2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: 步骤 5 中的图像 1,3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: 步骤 5 中的图像 2,3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: 步骤 5 中的图像 3,3
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: 步骤 6 中的图像 1,3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: 步骤 6 中的图像 2,3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: 步骤 6 中的图像 3,3
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: 步骤 7 中的图像 1,2 iRobot Roomba 655 Pet Series Drive Wheels Replacement: 步骤 7 中的图像 2,2
    • To go further into the holder to access the programming chips you can unscrew these compartments
结论
另外一个人完成了本指南。
Rhett
于01/22/15注册
1,329 声望
创作了7篇指南
团队
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G20
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 2,286
