跳转到主内容
iRobot Roomba 655 Pet Series Battery Replacement
你所需要的
  1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: 步骤 1 中的图像 2,2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: 步骤 2 中的图像 1,2 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: 步骤 3 中的图像 1,3 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: 步骤 3 中的图像 2,3 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: 步骤 3 中的图像 3,3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: 步骤 4 中的图像 1,2 iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: 步骤 4 中的图像 2,2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
结论
12等其他人完成本指南。
Matt Davis
于01/22/15注册
1,642 声望
创作了7篇指南
团队
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G20
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 42
总计 12,831
