跳转到主内容
iRobot Roomba 650 Main Wheel Replacement
你所需要的
  1. iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: 步骤 1 中的图像 2,2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: 步骤 2 中的图像 1,2 iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: 步骤 2 中的图像 2,2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Main Wheel Replacement, Main Wheels: 步骤 3 中的图像 1,2 iRobot Roomba 650 Main Wheel Replacement, Main Wheels: 步骤 3 中的图像 2,2
    • Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
    • The screws do not come all the way out.
    • Remove the wheels by pulling them out.
结论
4等其他人完成本指南。
Alex Schnorr
于01/22/15注册
649 声望
创作了3篇指南
团队
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G7
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 4,650
