跳转到主内容
iRobot Roomba 650 Caster Wheel Replacement
你所需要的
  1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: 步骤 1 中的图像 2,2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: 步骤 2 中的图像 1,2 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: 步骤 2 中的图像 2,2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: 步骤 3 中的图像 1,1
    • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
  4. iRobot Roomba 650 Caster Wheel Replacement: 步骤 4 中的图像 1,2 iRobot Roomba 650 Caster Wheel Replacement: 步骤 4 中的图像 2,2
    • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
结论
2等其他人完成本指南。
Alex Schnorr
于01/22/15注册
628 声望
创作了3篇指南
团队
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G7
4 名成员
创作了6篇指南
3条评论
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - 回复
Worked for my 690 as well.
Luke Oliver - 回复
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,146
