跳转到主内容
加入维修社区 - 创建账户
iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement
你所需要的
  1. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Removing the Side Brush: 步骤 1 中的图像 2,2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Bottom Panel Removal: 步骤 2 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Bottom Panel Removal: 步骤 2 中的图像 2,2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Battery: 步骤 3 中的图像 1,1
    • Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
    • In the unlikely event that the battery has leaked acid, avoid all contact with it and any surfaces it has affected. Wear protective gloves and wipe up any residue with a paper towel. Secure the battery in a plastic bag and dispose of it properly.
    • If you get battery acid on your skin or in your eye, flush immediately with water and seek medical attention.
  4. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Bumper Sensor IR Transmitter: 步骤 4 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement, Bumper Sensor IR Transmitter: 步骤 4 中的图像 2,2
    • Remove the front bumper. You may remove it with your hands or a tool. It should snap off with some effort. It will still be attached to the Roomba by a couple of wires.
  5. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 5 中的图像 2,2
    • Pull out the bin while pressing down on the release button. Set aside.
  6. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 6 中的图像 1,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 6 中的图像 2,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 6 中的图像 3,3
    • Remove the top plastic cover by first using a plastic opening tool or metal spudger around the edges. Then, carefully lift up from the back.
  7. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 7 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 7 中的图像 2,2
    • Use the Phillip's Head #1 Screwdriver to take out the 10 5 mm screws.
    • Continue to take out the two 5.5 mm screws with the Phillip's Head #2 Screwdriver.
    • Finally, remove the last 7.5 mm screw with the Phillip's Head #1 Screwdriver.
    • Lift the panel off and set aside.
  8. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 8 中的图像 1,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 8 中的图像 2,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 8 中的图像 3,3
    • Remove the yellow ring and the two plastic control panel covers.
  9. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 9 中的图像 1,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 9 中的图像 2,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 9 中的图像 3,3
    • Use the Phillip's #1 Screwdriver to remove the four 7.5 mm screws that hold the control panel to the motherboard.
    • Lift the control panel off, then lift the clear plastic motherboard protecting sheet and set both aside.
  10. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 10 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 10 中的图像 2,2
    • Use the Phillip's Head #1 Screwdriver to remove the five 5.5 mm motherboard screws.
    • Gently lift the motherboard up off the Roomba about half an inch.
  11. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 11 中的图像 1,1
    • Remove the round cliff sensor belt by pulling it up off of the front edge of the Roomba.
  12. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 12 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 12 中的图像 2,2
    • Disconnect the three cables that attach the motherboard to the front of the Roomba.
    • Lift up the motherboard, cliff sensor belt, and front bumper up and out of the way.
  13. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 13 中的图像 1,1
    • Remove the rubber cover on the bumper sensor.
  14. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 14 中的图像 1,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 14 中的图像 2,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 14 中的图像 3,3
    • Use the Phillip's #1 screwdriver to remove the two 7.5 mm screws from the bumper sensor module.
    • Pry the module clips open with a spudger or your finger.
    • Open the sensor module.
  15. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 15 中的图像 1,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 15 中的图像 2,3 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 15 中的图像 3,3
    • Once the bumper sensor module is open, remove the small IR chip.
    • Pull off the black protector surrounding the chip.
  16. iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 16 中的图像 1,2 iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement: 步骤 16 中的图像 2,2
    • For this next step, it might be helpful to have another set of hands.
    • Use a soldering iron to desolder pins on the blue IR receiver. Try repeatedly warming each pin up and giving a tug on the receiver. It should eventually slide out.
    • You will need to then solder in a new receiver in the exact same place you took the old one out.
结论
6等其他人完成本指南。
Alex Schnorr
于01/22/15注册
649 声望
创作了3篇指南
团队
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G7
4 名成员
创作了6篇指南
1指南评论
Hi, I am curious about this given what my 650 is doing... It turns on and runs for 2 minutes before I get the error about cleaning the wheels. Basically, the Roomba goes in a circle to the left and that's it. Occasionally, it will back up to the right, and then go in a faster circle to the left. If I hit the bumper it will go back to the right and then forward again to the left. I replaced the left wheel and it had no impact. Do you think it's the sensor? Thanks
Gordon Collins - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 39
总计 11,115
