跳转到主内容
加入维修社区 - 创建账户
iRobot Roomba 650 Battery Replacement
你所需要的
  1. iRobot Roomba 650 Battery Replacement, Removing the Side Brush: 步骤 1 中的图像 1,2 iRobot Roomba 650 Battery Replacement, Removing the Side Brush: 步骤 1 中的图像 2,2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: 步骤 2 中的图像 1,2 iRobot Roomba 650 Battery Replacement, Bottom Panel Removal: 步骤 2 中的图像 2,2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
    • In the unlikely event that the battery has leaked acid, avoid all contact with it and any surfaces it has affected. Wear protective gloves and wipe up any residue with a paper towel. Secure the battery in a plastic bag and dispose of it properly.
    • If you get battery acid on your skin or in your eye, flush immediately with water and seek medical attention.
结论
17等其他人完成本指南。
Charles Ward
于01/22/15注册
1,026 声望
创作了3篇指南
团队
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G7
4 名成员
创作了6篇指南
1指南评论
We thought we were going to have to put Boohya down (our toddler named it that) so he is very happy that by simply replacing the battery we brought him back to life! Thanks! $17 well spent.
Deedra Wollert - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 16
过去 30 天: 61
总计 19,038
