跳转到主内容
iRobot Roomba 595 Pet Series Wheel Spring Replacement
你所需要的
  1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Secondary Brush: 步骤 1 中的图像 1,1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 步骤 2 中的图像 1,1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: 步骤 3 中的图像 1,2 iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: 步骤 3 中的图像 2,2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Remove the Roomba's external underside.
  4. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 步骤 4 中的图像 1,1
    • Remove the 15 mm screws with the Phillips #0 screwdriver bit.
  5. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 步骤 5 中的图像 1,1
    • Once the screws have been taken care of, the wheel component (with the spring inside) can be removed from the main assembly.
  6. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 步骤 6 中的图像 1,3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: 步骤 6 中的图像 2,3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: 步骤 6 中的图像 3,3
    • Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
    • Carefully remove the spring from the component assembly as shown
    Where do you get replacement springs from?
    recklessl61 - 回复
结论
团队
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G5
3 名成员
创作了5篇指南
4条评论
My spring has fallen out and you don’t show where the spring attatches
Rebecca Hubber - 回复
Where can I get a new spring, mine is missing on the left wheel
emls23 - 回复
The bracket for the front (white and black) wheel broke. Where can I get a new one?
Kathryn Roberts - 回复
Where can I get a new spring for right wheel? Do these questions ever get answered?
KMF - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 1,643
