简介
This guide is useful for replacing a dead battery or a battery that cannot be recharged through the dock for some reason. This guide is pretty simple can be done in 3 steps, and won't break anything important
你所需要的
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
5等其他人完成本指南。
3条评论
Pls, can i charge the roomba directly, because the base is not working??
Yes I think so, mine can
Je dois chznger ma batterie qui est hs, mais les vis st morts, comment faire pour démonter le cache sans rien casser... sinon est ce que le cache et les vis peuvent être refournis par le sav?
