简介
Use this "Prerequisite Only" guide for removing the top silver and black panels for other replacements in the Roomba 560.
你所需要的
Flip the Roomba upside down.
Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
Turn the device over so that it is face up with the vacuum bin in front of you .
Press the button of the vacuum bin and pull out the bin from the device.
即将完成!
结论
