跳转到主内容
iRobot Roomba 560 Side Sweeper Replacement
你所需要的
  1. iRobot Roomba 560 Side Sweeper Replacement, Side Sweeper: 步骤 1 中的图像 1,1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Side Sweeper Replacement: 步骤 2 中的图像 1,1
    • Lift the yellow side sweeper, removing it from the device.
结论
3等其他人完成本指南。
Mairead Blaes
于10/01/15注册
825 声望
创作了4篇指南
团队
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G22
4 名成员
创作了14篇指南
2条评论
I need to replace the part on the bottom where the side sweeper screws in. The threads are stripped, I’m guessing, and screw won’t stay in.
Candy Schnurr - 回复
put some hot glue or melt some plastic in the hole before screwing it. you should get the threads back when you unscrew it
Nicolas Sicard -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 1,679
