跳转到主内容
iRobot Roomba 560 Handle Replacement
你所需要的
  1. iRobot Roomba 560 Handle Replacement, Side Sweeper: 步骤 1 中的图像 1,1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Handle Replacement: 步骤 2 中的图像 1,1
    • Lift the yellow side sweeper, removing it from the device.
  3. iRobot Roomba 560 Handle Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
  4. iRobot Roomba 560 Handle Replacement: 步骤 4 中的图像 1,1
    • Lift up the back panel to remove it from the device.
  5. iRobot Roomba 560 Handle Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 560 Handle Replacement: 步骤 5 中的图像 2,2
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
  6. iRobot Roomba 560 Handle Replacement, Clear Sensor Lens: 步骤 6 中的图像 1,1
    • Rotate the Roomba so the bumper is in front of you.
  7. iRobot Roomba 560 Handle Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
  8. iRobot Roomba 560 Handle Replacement: 步骤 8 中的图像 1,2 iRobot Roomba 560 Handle Replacement: 步骤 8 中的图像 2,2
    • Lift the thin top cover that holds the bumper in place.
  9. iRobot Roomba 560 Handle Replacement: 步骤 9 中的图像 1,1
    • Gently lift the device upwards from the bumper to detach these two pieces.
    • There are wires connecting the bumper to the device. Be careful while lifting the device off the bumper as to not damage these wires.
  10. iRobot Roomba 560 Handle Replacement: 步骤 10 中的图像 1,2 iRobot Roomba 560 Handle Replacement: 步骤 10 中的图像 2,2
    • Lift the bumper upwards for easier access.
    • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips #1 driver.
    • The sensor can be unplugged from the motherboard so the bumper isn't hanging off the Roomba.
  11. iRobot Roomba 560 Handle Replacement: 步骤 11 中的图像 1,2 iRobot Roomba 560 Handle Replacement: 步骤 11 中的图像 2,2
    • Lift the circular black panel off the lens.
    • Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
  12. iRobot Roomba 560 Handle Replacement, Top Panels: 步骤 12 中的图像 1,2 iRobot Roomba 560 Handle Replacement, Top Panels: 步骤 12 中的图像 2,2
    • Turn the device over so that it is face up with the vacuum bin in front of you .
    • Press the button of the vacuum bin and pull out the bin from the device.
  13. iRobot Roomba 560 Handle Replacement: 步骤 13 中的图像 1,1
    • Use your hands to unhook the snaps between the silver panel from the black panel located where the vacuum bin was.
  14. iRobot Roomba 560 Handle Replacement: 步骤 14 中的图像 1,3 iRobot Roomba 560 Handle Replacement: 步骤 14 中的图像 2,3 iRobot Roomba 560 Handle Replacement: 步骤 14 中的图像 3,3
    • Using the plastic opening tool, go around the outer edges of the silver panel and unhook the snaps holding it in place.
    • When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces.
  15. iRobot Roomba 560 Handle Replacement: 步骤 15 中的图像 1,2 iRobot Roomba 560 Handle Replacement: 步骤 15 中的图像 2,2
    • Lift the black handle and use the plastic opening tool to unhook the snaps underneath it.
    • Use the same tool to pry the silver cover from the black central control board.
  16. iRobot Roomba 560 Handle Replacement: 步骤 16 中的图像 1,3 iRobot Roomba 560 Handle Replacement: 步骤 16 中的图像 2,3 iRobot Roomba 560 Handle Replacement: 步骤 16 中的图像 3,3
    • Lift the silver panel off of the black panel.
  17. iRobot Roomba 560 Handle Replacement: 步骤 17 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the following screws:
    • Two 7.5 mm-long screws at either end of the semicircular handle
    • Ten 5 mm-long screws
    • Use a Phillips #1 screwdriver to remove the 5 mm-long screw at the bottom of the control board.
  18. iRobot Roomba 560 Handle Replacement: 步骤 18 中的图像 1,1
    • Lift the black panel off the device.
    • This will provide access to the motherboard and black circular control panel.
  19. iRobot Roomba 560 Handle Replacement, Handle: 步骤 19 中的图像 1,1
    • Hold the black panel in front of you with the handle facing the other side.
    • Locate the two hinges that will be pressed in the next step.
  20. iRobot Roomba 560 Handle Replacement: 步骤 20 中的图像 1,2 iRobot Roomba 560 Handle Replacement: 步骤 20 中的图像 2,2
    • Rotate the black panel so that the handle is now facing you.
    • Insert your hands through the rectangular holes.
    • Using your index fingers, press the hinges that were located in the previous step.
  21. iRobot Roomba 560 Handle Replacement: 步骤 21 中的图像 1,1
    • Lift the black handle for replacement.
结论
3等其他人完成本指南。
Davis Negrete
于10/01/15注册
176 声望
撰写一个指南
团队
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G22
4 名成员
创作了14篇指南
一条评论
Pour avoir terminé, je préciserai qu'il y a un sens pour remonter la lentille sinon le pare chocs ne coulisse pas.
De même, il n´est pas nécessaire de changer la lentille. Remettre celle d'origine (si elle n´est pas abîmée) convient très bien.
Excellent tutoriel !
Fabien-Antoine CHAPELLE - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 5,677
