跳转到主内容
iRobot Roomba 552 battery Replacement
你所需要的
    • to get started, remove the screws under the roomba and remove the secondary brush (yellow brush) and then pull up on the bottom panel.
    • under the castor wheel there is the battery, replace it with a new battery
    • when the battery is installed the robot will play a tone.
    • reseat the bottom panel and screw it back on. screw back on the secondary brush and charge.
结论
congrats! your roomba should be ready to go!
另外一个人完成了本指南。
Big builder
于01/23/24注册
132 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 72
