当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place your Roomba upside-down on a hard surface.
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Gently pull upwards on the brush to remove it.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Carefully lift the bottom plate.
The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver.
Gently lift the wheel to remove.
取消:我没有完成这个指南。
4等其他人完成本指南。
与3其他贡献者
于01/23/14注册
623 声望
创作了4篇指南
徽章: 15
+ 12更多徽章
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,269
