跳转到主内容
简介
This guide explains how to remove the side brush motor from your Roomba.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
    • Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
  8. Gently pull on motor assembly to remove.
    • Gently pull on motor assembly to remove.
结论
Aaron Jacobs
于2014年01月31日注册
534 信誉积分
创作了4篇指南
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 786
