当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place your Roomba upside-down on a hard surface.
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Gently pull upwards on the brush to remove it.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Carefully lift the bottom plate.
The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
Push on the dirt bin release button, and pull gently.
Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
Grab the brush case and pull upwards to remove.
Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
Repeat for the opposite side of the brush case.
Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case.
Pull off the back of the brush case.
Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place.
Remove the chip from its housing in the blue brush case.
Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate.
Pull out the motor and metal covering.
Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board.
Gently pull out the circuit board.
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于01/31/14注册
331 声望
创作了3篇指南
徽章: 8
+ 5更多徽章
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 17
总计 3,759
