跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide explains how to remove the main brush motor from your Roomba.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Push on the dirt bin release button, and pull gently.
    • Push on the dirt bin release button, and pull gently.
  9. Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
    • Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
  10. Grab the brush case and pull upwards to remove.
    • Grab the brush case and pull upwards to remove.
  11. Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach. Repeat for the opposite side of the brush case. Repeat for the opposite side of the brush case.
    • Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
    • Repeat for the opposite side of the brush case.
  12. Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case. Pull off the back of the brush case. Pull off the back of the brush case.
    • Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case.
    • Pull off the back of the brush case.
  13. Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place. Remove the chip from its housing in the blue brush case.
    • Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place.
    • Remove the chip from its housing in the blue brush case.
  14. Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place. Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
    • Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
  15. Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate. Pull out the motor and metal covering.
    • Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate.
    • Pull out the motor and metal covering.
  16. Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board. Gently pull out the circuit board. Gently pull out the circuit board.
    • Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board.
    • Gently pull out the circuit board.
结论
2等其他人完成本指南。
John McTigue
于2014年01月31日注册
331 信誉积分
创作了3篇指南
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了13篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 17
总计 3,388
