跳转到主内容
iRobot Roomba 551 Bumper Sensor Replacement
你所需要的
  1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: 步骤 1 中的图像 1,1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 2 中的图像 1,1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 3 中的图像 1,1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: 步骤 4 中的图像 1,1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 551 Bumper Sensor Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: 步骤 7 中的图像 1,3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: 步骤 7 中的图像 2,3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: 步骤 7 中的图像 3,3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 8 中的图像 1,1
    • Lift the bottom cover and set it to the side.
  9. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 9 中的图像 1,2 iRobot Roomba 551 Bumper Sensor Replacement: 步骤 9 中的图像 2,2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  10. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: 步骤 10 中的图像 1,1
    • Flip the Roomba so that the bottom is facing you.
  11. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 11 中的图像 1,2 iRobot Roomba 551 Bumper Sensor Replacement: 步骤 11 中的图像 2,2
    • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
  12. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 12 中的图像 1,1
    • Pull gently on the bottom of the sensor to remove.
  13. iRobot Roomba 551 Bumper Sensor Replacement: 步骤 13 中的图像 1,3 iRobot Roomba 551 Bumper Sensor Replacement: 步骤 13 中的图像 2,3 iRobot Roomba 551 Bumper Sensor Replacement: 步骤 13 中的图像 3,3
    • Flip the bumper over and lift the sensor from its compartment.
    • You are now free to replace the bumper sensor.
结论
4等其他人完成本指南。
Cody Rhoads
于01/16/14注册
348 声望
创作了2篇指南
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 4,655
