跳转到主内容
iRobot Roomba 551 Brushes Replacement
你所需要的
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: 步骤 1 中的图像 1,1
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - 回复
  2. iRobot Roomba 551 Brushes Replacement: 步骤 2 中的图像 1,1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: 步骤 3 中的图像 1,1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: 步骤 4 中的图像 1,1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 551 Brushes Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: 步骤 7 中的图像 1,2 iRobot Roomba 551 Brushes Replacement, Brushes: 步骤 7 中的图像 2,2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: 步骤 8 中的图像 1,3 iRobot Roomba 551 Brushes Replacement: 步骤 8 中的图像 2,3 iRobot Roomba 551 Brushes Replacement: 步骤 8 中的图像 3,3
    • Grab each brush and lift upwards to remove.
结论
John McTigue
于01/31/14注册
331 声望
创作了3篇指南
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
2条评论
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - 回复
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 99
过去 30 天: 444
总计 6,204
