简介
This guide explains how to remove the brush case from your Roomba.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  6. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Push on the dirt bin release button, and pull gently.
    • Push on the dirt bin release button, and pull gently.
  9. Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
    • Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
  10. Grab the brush case and pull upwards to remove.
    • Grab the brush case and pull upwards to remove.
结论
另外一个人完成了本指南。
John McTigue
于2014年01月31日注册
331 信誉积分
创作了3篇指南
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了13篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 4
总计 503
