跳转到主内容
iRobot Roomba 551 Battery Replacement
你所需要的
  1. iRobot Roomba 551  Battery Replacement, Side Brush: 步骤 1 中的图像 1,1
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - 回复
  2. iRobot Roomba 551  Battery Replacement: 步骤 2 中的图像 1,1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: 步骤 3 中的图像 1,1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: 步骤 4 中的图像 1,1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 551  Battery Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: 步骤 7 中的图像 1,2 iRobot Roomba 551  Battery Replacement, Battery: 步骤 7 中的图像 2,2
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
结论
6等其他人完成本指南。
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
一条评论
Thank you Deborah!
James - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 114
总计 9,705
