跳转到主内容
iRobot Roomba 4160 Brush Replacement
  1. iRobot Roomba 4160 Brush Replacement, Brush Guard: 步骤 1 中的图像 1,1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Replacement: 步骤 2 中的图像 1,1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 4160 Brush Replacement: 步骤 3 中的图像 2,2
    • After the guard hinges up, lift the guard up and away from the Roomba.
  4. iRobot Roomba 4160 Brush Replacement, Brush: 步骤 4 中的图像 1,1
    • Remove the wire brush by grabbing it by the yellow plastic part of the brush.
    • Pull the brush upwards until it comes out.
  5. iRobot Roomba 4160 Brush Replacement: 步骤 5 中的图像 1,2 iRobot Roomba 4160 Brush Replacement: 步骤 5 中的图像 2,2
    • Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
    • Pull the brush upwards until it dislodges.
结论
2等其他人完成本指南。
noah falck
于04/07/14注册
104 声望
撰写一个指南
团队
Cal Poly, Team 6-4, Forte Spring 2014 Cal Poly, Team 6-4, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G4
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 304
