跳转到主内容
iRobot Roomba 4160 Brush Guard Replacement
  1. iRobot Roomba 4160 Brush Guard Replacement, Brush Guard: 步骤 1 中的图像 1,1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Guard Replacement: 步骤 2 中的图像 1,1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Guard Replacement: 步骤 3 中的图像 1,2 iRobot Roomba 4160 Brush Guard Replacement: 步骤 3 中的图像 2,2
    • After the guard hinges up, lift the guard up and away from the Roomba.
结论
Philippe Napaa
于04/07/14注册
222 声望
创作了2篇指南
团队
Cal Poly, Team 6-4, Forte Spring 2014 Cal Poly, Team 6-4, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G4
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 317
