跳转到主内容
简介
This is an easy guide. It should only take a few minutes to complete and it doesn't require any tools.
工具
没有特定工具。
配件
没有特定配件。
  1. Lay the Roomba upside down on a flat surface with the blue strip away from you.
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. Use your index fingers to pull the yellow tabs towards you. While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. Pull back the brush guard to unhook it from the latches.
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
  4. Set the brush guard aside.
    • Set the brush guard aside.
    • The main brush is the bristly one that is closest to the blue strip.
  5. Remove the main brush by grabbing it and pulling it up and out of the Roomba. For reassembly, orient the Roomba with the battery closest to you:
    • Remove the main brush by grabbing it and pulling it up and out of the Roomba.
    • For reassembly, orient the Roomba with the battery closest to you:
    • First, insert the black end of the main brush into the black square opening on the right side.
    • Second, lay the main brush back into place.
结论
Samantha Barrett
于2014年01月13日注册
501 信誉积分
创作了5篇指南
团队
Cal Poly, Team 17-5, Forte Winter 2014 Cal Poly, Team 17-5, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G5
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 447
