当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use your index fingers to pull the yellow tabs towards you.
While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
For reassembly, make sure to push in the brush guard until it clicks into place.
Pull back the brush guard to unhook it from the latches.
Remove the brush guard by lifting it up and out of the Roomba.
This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
