跳转到主内容
iRobot Roomba 4100 Brush Guard Replacement
  1. iRobot Roomba 4100 Brush Guard Replacement, Brush Guard: 步骤 1 中的图像 1,1
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. iRobot Roomba 4100 Brush Guard Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 4100 Brush Guard Replacement: 步骤 2 中的图像 2,2
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. iRobot Roomba 4100 Brush Guard Replacement: 步骤 3 中的图像 1,1
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
结论
Samantha Barrett
于01/13/14注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 17-5, Forte Winter 2014 Cal Poly, Team 17-5, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G5
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 716
