跳转到主内容
iRobot Roomba 4100 Battery Pack Replacement
你所需要的
  1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: 步骤 1 中的图像 1,1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. iRobot Roomba 4100 Battery Pack Replacement: 步骤 2 中的图像 1,2 iRobot Roomba 4100 Battery Pack Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. iRobot Roomba 4100 Battery Pack Replacement: 步骤 3 中的图像 1,1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
结论
Your iRobot Roomba 4100 is now ready for use.
2等其他人完成本指南。
Scott Leonard
于10/05/10注册
445 声望
创作了3篇指南
团队
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G6
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 8,417
