本指南有最近更改,您可查看未经巡查的最新版本。
简介
If your iRobot Mint is having trouble moving, this guide will show you how to take it apart and get it going again.
你所需要的
Eight Phillips screws are located underneath the stickers.
Carefully cut around the 8 screw holes using an X-acto knife or razor blade to reveal the screws.
Remove the screws with a #2 Phillips screwdriver.
With the device upside down, pull up to separate the bottom from the top cover.
Locate the three arrows on each wheel.
Insert metal spudger at arrow locations to pop off the wheel covers.
Remove four #2 Phillips and lift off retainer.
Pull out all weights and set aside
另外一个人完成了本指南。
2条评论
Nice! Very helpful.
Popping the wheel covers as shown breaks the small hooks that hold the wheel cover on. You need to rotate the cover clock wise to release them. There probably is a special tool that uses the small impressions in the cover.
